Hello everyone. I am using Lenovo Thinkpad having the fingerprint reader in it. How can I use Lenovo fingerprint protect files? Is it possible to the fingerprint reader to protect my documents and stuff? How can I do it? I need any other suggestions. Thank you.
How to use Lenovo fingerprint protect files
If you want to solve this problem, buy a USB-serial adapter, or you can make it yourself. Here are the materials you need to make one:
1. 4 push-buttons
2. SERIAL connector
3. Connector Box
4. Cable
5. Soldering iron and accessories .
If you can make it successfully, your problem will be solved. For more information, see this link: http://www.instructables.com/id/External-Winamp-Control/
