Hi all users,
I have read an article about lifsoft application that will automatically resumes from power off mode or wake-up from sleep mode. I just want to know is this application really available on net and is it working or not. Can anyone know about lifsoft app, let me also know how to use it on laptop/systems.
How to use lifsoft application on system.
Hi Toby,
Now a day lifsoft application is really available on the net and it is working. Just think that you are going to office at 9am and you just don’t need to bother about the shutdown of your home PC and your office PC will also be started automatically before 1min you reach. Isn’t it interesting. It’s easy to use. You can also set up task for other jobs like visiting URLS, open specific program etc.
You can visit the listed URLs where you can buy or download a free trial of lifsoft app for your laptop/systems. https://en.softonic.com/s/lifsoft-free
You can get a trial version from softonic and also can buy the software from here.
http://www.freedownloadscenter.com/Authors/Lifsoft_INC.html
Free download center is also a helpful and famous site for software download. You can get a free version from here. http://www.bestdownloadreview.com/download/lifsoft-pc-zeitschaltuhr-97391.html
Best download review is a support site for several software. You can also download the software from here.
Just follow the download instruction and install the software.
Good Luck.
