Hi all, I am using Office 2011 for Mac in my Mac OSX. I would like to know about how the eraser tool works with Mac word, will I be able to erase the image inside the word file as I do it in MS Paint, Please advice me how to use Mac Word eraser. Thanks
How to use Mac Word eraser
Hi James,
Just simply follow these simple steps:
1. Click the picture, the picture toolbar should appear this time.
2. Turn the toolbar on manual by doing this View > toolbar > picture
3. Click selection tools.
4. Use the right selection tool in selecting the picture's area that you want to delete, cut or edit.
5. And then click EDIT > cut or remove.
Or if you don't want to do it trick, you can use a graphic editing software or any software that can finalize your picture before inserting it into your document.
Hope this will answer your question.
