kenn1234
10 points
Posted on - 10/11/2011
Halo every one,
Do explain how to install and use magicjack on my Laptop ? And the advantages and disadvantages of Magicjack?
How to plug in the USB to the Laptop? Does it require a wireless telephone connection or a landline is also fine? Do explain me the above details.
Thank you.
Lemon
How to use magicjack on my Laptop
The magicJack is particularly a USB device. It is  also known as a USB telephone adapter and can work better on any computer that has a USB port. It allows users to make limitless local and long distance telephone calls throughout a regular phone. So of course, it may work on your laptop computer if it has a USB port functions well. To install magicJack you need to install run.exe file on to your computer.Â
          ![](https://www.techyv.com/sites/default/files/users/Lemon/MagicJack.png)
Advantages of magicJack:
1. Free directory assistance.
2. Free caller ID.
3. Free call waiting.
4. Free voice mailing and much more.
Hope you have got your question's answer.
Thank you.
Lemon
