How to use Media Player script for MSN with winamp ?
Can anyone give me the winamp media player script for MSN which displays my now playing status on MSN. I don’t want to use Windows Media Player?
Hello, you can follow the step here to integrate winamp with MSN
Hope this can help you
Hi Acke Zimri
You just have to download a plug in for you to do that. It’s called Messenger 7 plug in.
 Here is the link https://haanstra.eu/messengeramp/index.html.
After you download it you can install it right away then you have it Winamp media player displays now playing status on your MSN.
Hope it helps.
Winamp is by far the best music player that I have ever utilized, so I would love to use it everywhere. But, I could not find out how to use it on MSN, the greatest chatting software. Now everyday I use Winamp along with MSN without any problems! This is now possible for me after reading these posts. The people that answered the post gave very useful answers. Thanks to both of you. It is just easier to use by just installing the plug-in in Winamp and I have found the extension from the link that Peiann Frank supplied to me. Thank you friend.
