I just purchased a 32 GB Samsung Galaxy Tab 8.9 4G that has the NVIDIA Tegra 2 T20 chipset, 1 GB RAM, Dual-core 1.5 GHz Cortex-A9 CPU, ULP GeForce GPU and Android OS Honeycomb.Â
I just want to know if there is an MS Office app and how to use MS Office in Galaxy Tab?
How to use ms office in galaxy tab 8.9?
Hi Dudley,
There are a lot of apps that you can download to use MS Office.
I will give you two good examples that I have tested and user friendly.
1. Polaris Office
This is one of the most popular apps to edit, view, create and manage your documents in MS Office.
You can view the tutorial here:
2. ThinkFree Office
This is also a well-known MS Office app with the same functions like Polaris Office.
Hello Dudley,
There is a professional application with which you can create, edit print and share your MS office docs from your phone or your tab, it allows you to read your Ms office docs.
It is called Smart office 2
This is the link from Google play:
And this is the video review of the application:
Enjoy!
