How to use network map software to create map?
I am looking for the best solution for mapping a network that is free forever including live support and updates of all products. It also offers to access the network monitoring and management tools. So, I need to know how to use network map software to create network map .
Answered By 0 points N/A #138704
First of all you have to get knowledge about the Network Map and also have knowledge of using it.here is the procedure that you have to follow
1.You have to change the view between all devices and backbone with the help of drop-down menu that is in the network toolbar.
2.You will be able to read the Network Map.
3.Learn about navigating the Network Map.
4.Then change the layout of the network Map.
5.Then you will get information about the devices.
