How To Use NIC Teaming Server 2008?
I am constructing a new Server for making it the file server for the organization. I need to know the basics of the NIC teaming server 2008. Can you please help me?
To set up NIC server you need to know only a few things
• If you have multiple NIC you can set up eight different configuration
• Consider having two clients that are connected to a single switch and another end there is a file server with disabled activity not enabled. This configuration is called standalone file server.
• From the above configuration if you are making the file server with multiple IP addresses. It’s called multiple file server, teamed.
• Other configurations can be set up by adding more clients and routers to the network map.
