How to use Nokia map on Nokia N9?
I bought a Nokia N9 but yet I am not quite comfortable with its map feature. How to use Nokia map on Nokia N9? Give me some tips.
The Nokia N9 is a smartphone that came from Finns, this devices is a very decent kit. The body, screen swipes, and also the call quality is much better for iPhone 4S. It has a quick Office, access to Facebook and Maps. Has free built for map navigation, great keyboard, and have an accurate and support swipe input and its writing input.
The battery life is also good. Even if the N9 is the last product that would be introduced it will instill that spectacular experience in using such device. If you want the combination of form and function then this what you need minus the flamboyant art design then this is the device that is built for you. Heres a link for a video demonstration on how to use the N9 Map.
Dear,
The Nokia N9 provides new mapping software. It is constantly updated which introduce new features. In order to use the software you need internet connection on your phone and maps application.
You can connect https://www.here.com/en with your Nokia N9.
Hope this will solve your problem.
Thank you.
