How to use nokia n96 photo editor?
Asked By 100 points N/A Posted on -
How to use Nokia n96 photo editor? They're some built in photo editors in Nokia mobile phones as well as with other mobile brands, I was just thinking if how to manipulate the features and explore the possible designs to be used. Share with me your experiences based on Nokia n96 mobile phone, and give me some advice.
Thank you.
Best Answer by Taylor Adrit
Answered By 0 points N/A #183985
Hi kathry good day and regarding to a photo editor in the mobile NOKIA N96 there are certain options available.
Just go to Images and then open an existing photo and followed with the option 'Edit' then first rotate that photo to the correct resolution and check that is not rotated downwards and with the help of options select the command 'Save'.
If the bar is displayed showing the status of progress then it indicates that change is being processed for your device in which the image you have selected.
Thank You.
Answered By 0 points N/A #183986
Hello Kathryn,
To use the Nokia n96 photo editing app, you will need to do the following:
  • You will need to use the phone to open a photo,
  • And select 'Edit' from options.
  • After that you will need to rotate my photos to the correct composition in the event that they are upside down.
  • And then make any other changes you want and then 'Save'.
Nicke
