I use outlook 2007 and my PST files have been corrupted. How can I repair the files.
Someone suggests me nucleus kernel PST repair tool but he has not used it himself.
Will it work?
How download, install and take action with it?
Please help me.
How to use nucleus kernel PST repair tool?
Hello there Robert,
You may repair your files by using some software's.
Kernel for PST Repair is tool for outlook that facilitates the recovery of files in just a few mouse clicks.
You may download it free, or you may buy it online.
To download or buy this software just visit and once you successfully download it, install it, and run the program and done.
Hope it helps you.
Regards Ronald
Hello Mr Robert,
You can repair corrupted Personal Folders file (. PST) or your Offline Folder file (.ost) by using the Inbox Repair Tool (Scanpst.exe).
It can diagnose and repair corrupt files. Scanpst.exe is installed when you install Outlook.
You can locate it at:
Drive:Program FilesMicrosoft OfficeOFFICE12
Please Go Here to get the detailed process of repairing corrupted .PST files.Â
Hope this solves your problem.
Best regards.
