How to use partition find and mount software to recover deleted partition.
Hallo. I happened to have deleted my recovery partition during a windows boot. A friend advised that I use partition find and mount software to recover the partition. However, I have tried fast intellectual scan, normal scan and thorough scan but to no avail. How do I recover this vital partition? How about if this drive has been formatted more than once? Thanks in advance.
Best Answer by Justin C Amato
Answered By 0 points N/A #163881
You can also use the windows 7 image backup tool to create an image of your c drive. This way, if your windows installation becomes corrupt, you can restore it to your last saved image.
See this link for more information on backup and restore: https://support.microsoft.com/en-us/products/windows
You can also use the Easeus Todo manager, as explained here: https://www.cnet.com/how-to/free-backup-utility-outshines-windows-7s-built-in-disk-imager/
Answered By 80 points N/A #163880
Hello Conrad,
I assume that your operating system is still working fine. It is somewhat difficult to recover the recovery partition.
However you might be able to recover the partition using Partition Wizard Bootable Disk
If it fails (assuming your copy of operating system is working fine) you can create a new recovery partition using ANARETHOS RECOVERY TOOLS
It will create a new recovery partition using the current Windows installation.
Answered By 0 points N/A #163882
Hello Conrd,
There are also other programs that might help you a lot. Visit this techyv page.
Would like to know how to partition my hard drive
