Hi everyone,
How to use pc suite for nokia 6600 windows7? I would like to know the compatibility matter between a pc suite nokia 6600 unit and windows 7 operating system. Is it possible to insert a nokia 6600 mobile phone in a computer desktop with windows 7 operating system? There are important files to be transferred.
How to use pc suite for Nokia 6600 Windows7?
Hi there,
You can simply download Nokia PC Suite from the following link:
www.softpedia.com
You can use this software for windows 7 without any compatibility issues. Firstly you need to download the software form the above mentioned website and then install it on your pc having Windows 7.
Now you can connect your Nokia 6600 using a USB cable. Your desktop will show a notification that your Nokia 6600 phone is now connected to the pc. As you get this notification, you can now easily transfer the files between your pc and your phone.
If you open My Computer, you will see your device(Nokia 6600) there and you can open the files on your phone from here. You can transfer the data using simple cut-copy-paste.
Good Luck.
To connect your Nokia 6600 to your computer which is running Windows 7,
Follow the steps below
1. Download the latest version of Nokia PC Suite for Nokia 6600 from this site: http://pc-suite-for-nokia-6600.software.informer.com/1.0/
2. Install the program and follow the instructions. You will see a shortcut on your desktop called Nokia 6600.
3. Double-click the shortcut.
4. You will be prompted to connect your phone to the computer via USB. Connect it and follow the instructions.
5. You will find options to copy data to and from your Nokia 6600 phone.
