How to use a Plugin color harmony Photoshop Mac
Hello. I downloaded this photoshop in Mac and don't know how to use it. How to use this plugin color harmony photoshop Mac briefly? Please explain in the instructions. Thanks a lot.
Before you are able to use the Color Harmony plug-in in Photoshop, you must first install the plugin into the Photoshop. All you have to do is copy the plugin into the Photoshop Plug-in folder located normally in ApplicationsAdobe Photoshop CS5Plug-Ins (MAC users only). Do not forget that before you copy the file into the folder, make sure that Photoshop is closed.
After the installation, open up the Photoshop and the plug-in is available in the menu filter.
Gibson
