Hello Guys,
I am using MS PowerPoint 2010 in my PC, I need to know how to use PPT progress bar percentage in the presentation. Please do the needful for explaining it in detail, so that I can create my presentations more appealing using the progress bar.
Thanks,
Horace T Perry
How to use PPT progress bar percentage
Hi Horace,
The steps to add progress bar to PowerPoint presentation are as follows:
1) Complete the presentation, Go to 'Tools', Select 'Macro', Click 'Visual Basic Editor'
2) In the new window, select 'Insert', click 'Module' and copy the below text
3) Sub AddProgressBar()
  On Error Resume Next
  With ActivePresentation
  For X = 1 To Slides.Count
  .Slides(X).Shapes("PB").Delete
  Set s=.Slides(X).Shapes.AddShape(msoShapeRectangle,_0,.PageSetup.SlideHeight-12,_X*.PageSetup.SlideWidth/.Slides.Count,12)
  s.Fill.ForeColor.RGB=RGB(127,0,0)
  s.Name="PB"
  Next X:
  End With
  End Sub
4) Go to 'File', > 'Close' > 'Return to Microsoft PowerPoint'
5) In the PowerPoint page, Go to 'Tools' > 'Macro' > 'Macros'
6) Select the 'AddProgressBar', click 'Execute'
