Hello Guys,
How to use project 2010 PowerPoint? I just learn how to use PowerPoint but not about how they are related to this project 2010. Can you give me a website that will best explain the relationship between PowerPoint and project 2010? I just want to be aware on how they are use together.
Thank you.
How to use project 2010 powerpoint?
Learning PowerPoint is not a great deal you can learn it in few hours.
You will find hundreds of tutorial to learn PowerPoint.
But I will suggest you to use Microsoft tutorial to lean PowerPoint.
It will increase you understanding more as compare to any other tutorial.
You can check that tutorial here.
Hi Travis,
The Project 2010 can be used for work management. It can be used for individuals and in firms. You can manage you project with this tool. There are different tools to do all your work. You can set time limits, Schedule meetings, team builder etc. this will be a very helpful tool for project managers. There is project professional 2010 which include all the features of 2010 plus some additional features. Project 2010 is the latest version .Project 2003, 2007 are available. . You can get more information on Microsoft’s website. If you are getting a chance to work with, go for it. Better study from hand on experience.
