How to use qvod Player
Hi Experts,
I am looking for player by which, I can watch video and movies online. Some one suggest me use qvod player. I have downloaded and install in Windows XP Operating system but I don't know how to use qvod. Please provide me the complete tutorial about "how to use qvod player".Thanks.
Jerold Kramer
Best Answer by cathy emrald
Answered By 0 points N/A #166780
After installing your Qvod Player, go to your browser, and open a site that supports streaming and downloading of P2P movies. One example is www.tom365.com
  • Then, choose a movie and click the URL at the address link.
  • Then, allow the Qvod player to run and wait at least 30 seconds for it to buffer.
  • Open your Qvod player, and you will see a new task tab, which is the one you will click in your browser.
  • You may double click the task and let it buffer.
  • You can wait until the player finishes downloading the movie.
  • Last, in the download directory, find the downloaded movie. After installing your Qvod Player, go to your browser, and open a site that supports streaming and downloading of P2P movies, one example is https://inicholas.net/use-qvod-to-download-watch-movies/
Answered By 5 points N/A #166781
Qvod Player is an all-in-one media player that handles P2P download and streaming. But this player is a Chinese player so the tutorial below is for those non-Chinese users. Go to http://www.qvod.com to download the player. The website is in full Chinese characters so use Google Chrome browser to transfer the page into English. Or you can also download here. To start using it, it is required that you use Internet Explorer or Firefox.
1. Launch Internet Explorer and then search for a website that supports P2P download or streaming. (You can try here.)
2. Choose a movie and then click the link below the image. The link is the title of the picture shown.
3. If you are a first timer, notice the yellow tab on top of your browser that notifies you about the ActiveX plug-in. Click it to enable the ActiveX Control.
4. Allow the Qvod Player to run on the window that will pop up. Just click the first button to allow if it is on Chinese language.
5. The Qvod player will pop up now and the movie will start to buffer in your browser. Wait until it finishes buffering.
6. Click the Qvod player. If the task is on the Net Tasks tab, then you can close IE.
7. Double-click the task and wait till it finishes downloading so you can watch without interruption.
8. After downloading, you can find your movie on your download directory. The default location is on your Download folder under your C: drive.
To change the language on your player, simply click on the File > Language > English
Answered By 0 points N/A #166782
Hello Jerold Kramer,
Its my pleasure to help you. Lot of sites there in internet to learn about qvod player. I will give you a recommended site to learn it. It is really helpful tutorial. Go to the link given below.
http://www.howtox.net/?f
Be careful for not to install the player in the Chinese path. After the installation find the movie that you need to watch, click the watch button on it, then the IE window will pop up to prompt, when need, select always allow. under usual quality to normal viewing, if not, please continue to look foreword.
This will really work for you.
Thank you.
