How to use radio PSD template for a live FM radio streaming?
How to start using the radio PSD template?
Is it available to use for the FM radio station?
How to use radio PSD template for live streaming?
Dear user,
I have done a research on Google for your F.M radio templates. If you are using an android, then here is a website from which you can download F.M radio PSD Application:
https://downloadpsd.cc/icons/android-fm-radio-application-psd
You can download templates from this website for F.M radio:
http://all-free-download.com/free-website-templates/radio.html
You can also download more related PSD files from the above website.
Hope this will help you.
Thank you.
Hi Jenelyn,
Yes you can definitely use the PSD template for live streaming.
One of the best templates that you can use is “PSD Radio” while clicking the link below.
Below one will provide a template that you can edit it to your own comfort as well.
http://www.learnfromnet.in/2013/01/free-psd-website-template-red-color.html
Just download it and start using.
Hope this helps.
Thanks
Baker
Notifications
