How to use ralink airport download for WI-fi adapter?
Hi. I have purchased a D – Link DWA-125 and it is working well but I have to manually connect it every time I boot the computer. Then Someone told me to use about ralink airport download. So I installed it but do not know how to configure automatically connect when system starts. As I am using Mac OS lion for it. Please guide me what to do.
Answered By 30 points N/A #131535
Hi Steveen Jordan,
Thanks for raising the problem. You have already done the majority of the configuration by successfully connecting Ralink with Wi-Fi router. You just have to follow the below steps so that it automatically connects when the system starts.
Step 1: First go to the Users & Groups window
Step 2: Then into the Login items
Step 3: In this step you have to add & select the Ralink using the plus(+).
It will be appearing in the application folder after all 3 steps have been successfully completed.
Then verify it by rebooting the OS and you will Ralink is automatically connecting to Wi-Fi router you have.
That solves your problem.
Thanks & Regards,
DBD
