How to use raw image as a bootable Windows image with rdp
Hi Experts,
I have created a raw image and wanted to know how can I use this as a bootable windows image with rdp. Can you show me a step by step guide? Thank you in advance for the help.
Hi Experts,
Windows Bootable Image Creator is an app used to create a bootable Image file which only works on Windows XP, Vista and 7 files. It provides a quick solution in case Windows installation files are stored in a folder in your hard disks, Windows Bootable Image Creator and to create bootable ISO image.
You are presented w/ configuration when you start the program. Click it and the introductory screen appears. Then, select the operating system, CD/DVD labels, setup location and output path.
You create an Iso from the first menu in the operating system, in the second pickup a custom label.
You need to point to the extracted Windows setup folder to setup location. You need to pick a folder w/ instillation files because you can’t pick the folder. Pick an output w/ enough storage to hold the Iso image. This processing may take a while but it also depends on overall performance and write speed of the computer to create the Iso image. Users will not need tool if they have Windows setup files on disc or corrupted installation that is readable.
Hope this information will help you.
