How to use remote desktop connection?
Remote assistance is a tool that allows the user to interact with each other by accessing their computers over the internet. It allows you to view another system with the owner's permission to be able to see and identify if there is a problem with the system instead of going to their place directly. It allows the user to control and fix the computer through the internet. And also, it can let you access your home PC for transferring files while you are not at home. Click the link below for the step-by-step method on using Remote Assistance:
http://www.jakeludington.com/ask_jake/20051122_how_to_use_remote_desktop_connection_rdc.html
Thank you very much for the information about remote accessing. I have been thinking of having a remote access to my pc. But I didn’t know how to make it work. The link you provided helped me a lot.
Thank you very much.
