Hello experts,
I have downloaded Paltalk Massenger and installed it. I am using it for first time. I need to know of using RGB color light for Paltalk. How can I use RGB color light when I am using Paltalk.
Please leave your comments.
How to use RGB color effect for Paltalk.
Hello Eliza Dunley,
Good day!
It's good that you have posted your concern on this site. I hope you are enjoying Paltalk. With Paltalk you can color your nick. They allow you to modify settings online. On how it works, you can check this:
Regarding RGB light color it is indeed possible for you to define the RGB values you can try to check on the links I have posted below.
http://www.paltalk.t83.net/
Good luck!
Rios Louise
