How to use sccm to meter Adobe?
Hello guys,
I want to ask if how to use sccm to meter adobe? There are some many applications that adobe has and I want to make a study of all the packages that are included. I need you suggestions,
Thank you.
Hello guys,
Thank you.
Hello Acke Zimri,
When I searched the forum of Adobe for some possible solution to your concern, I have seen some topics that is related to your problem which may help you a lot. Kindly Click the link below for more information:
Adobe Forum: SCCM patches-Adobe product updates
you may also find this link helpful:
Noob Windows: Windows Updates in SCCM 2012 Implementation, LImitations and Concerns
