How to use the security cam from my Mac?
Hello experts,
How to use the security cam from my mac? I am using mac operating system for 2 weeks and not yet familiarize all the functions and hotkeys of the said operating system. Can you help me on how can I get the security cam from my mac? If there are some ways to get an access for it please give me some ways.
Thank you.
Answered By 5 points N/A #150343
If you're planning to setup a security cam that can be operated on and viewed from your mac, then the first thing to do is to scout for a security cam that is compatible with your mac. Once you find one, that security cam would definitely have a driver and software program CD/DVD that you will install. The driver will automatically install and make your mac identify that cam. You can then install and use the application that comes with your cam to whatever application you need, including serving as a security cam.
