How to use server asset database through unity?
I want to set up my pc as server. I will have my PC as the main server and want to connect some workstations with it. Unity is the interaction software I want to use. But I do not know the proper using method. How to use server asset database through unity? If you have any other suggestions rather than unity and has the full process regarding server asset database please do reply.
I will be looking forward to having answer from experts.
Answered By 10 points N/A #164481
There are many tools that will help you transform your PC as a server. Unity is a very effective tool to convert your PC to a server. Before you convert your PC to a server, follow the steps below:
1. Before converting your pc to a server, make a backup copy of all the files on the system. Do not choose a custom backup; select the full backup as the custom backup does not backup all the system files.
2. Install a trusted antivirus software on the system. This is a very important step as it is concerned to the safety of your data. As you are converting your pc to a server, it is very essential to protect the data. If the server is effected the all the workstations connected to it will be disconnected.
3. Keep checking the performance of server regularly and verify any errors immediately. This way, you will get an optimum performance.
