How to use SharePoint foundation filter web part effectively?
Greetings Techyv members. Hope all is well. I would like to ask how to use sharepoint foundation filter web part effectively? Please also cite its importance as well as its pros and cons. I would also appreciate a step by step guide for this. I'm looking forward for your reply.
Answered By 5 points N/A #153014
Hello Ryan,
Here I am giving your answers:
Using filters
There are three steps to using a Sharepoint foundation filter:
•       Adding the filter to your Web page
•       Configuration of the filter settings
•       (Optionally) Connecting the filter to other Web Parts on the page
Adding a filter Web Part to a page
When you will start using a filter that will request user input.
Make the place for the Web Part on the page & provide a name for the filter in the text box or menu as the description given on the page.
You can organize the settings of the filter by the Web Part tool pane. Each tool pane has special options depending on the type of filter.
You need to connect the filter Web Part that you are going use to another Web Part on the page. You can connect two types of filters Web Parts.
They are the visible one & another invisible to the user. After adding a filter, you can connect to another Web Part on the page.
You can start a connection between the filter Web Part and other Web Part on the page.
Benefits:
·         Financial report making.
·         Operating automatically.
·         Social computing
·         Web content management
·         eDiscovery.
·         Powerpoint conversation
·         Secure store service.
