How to use a simple dynamics ax blueprint
I have seen many example of blueprint from Ms dynamics ax, but I don't know the process behind it.What is the first step to use dynamics ax blueprint?
There are many examples of blueprint from MS dynamics ax. The process behind it is very simple. To design a blueprint, follow the steps below:
1. Download Dynamics AX blueprint for windows. You can get it here – http://softwaretopic.informer.com/dynamics-ax-blueprint/.
2. Save the file on your desktop.
3. After downloading, install the software on your computer.
4. Then open the software and setup the profile according to the instructions given.Â
Now you are ready to create the required blueprint.
