alec hughes
20 points
Posted on - 03/31/2012
I Just bought a new iPhone 4s and try to use SIRI application, But it says that I need to comeback later. Everytime I open that application thats the only thing that it say. Please help me. Do I need a server to connect my SIRI ? Or do I need to configure it first?
How to use SIRI on iPhone 4s
Speech Interpretation and Recognition Interface or SIRI for short is available for Apple's iPhone 4S only. This newest phone will prompt you if you want to enable the SIRI feature. SIRI is a voice associate that lets you talk to your iPhone and let it act on your commands. To fix this issue, try the following solutions below:
1. Enable SIRI by going in to Settings and then tap General and then SIRI. Enable SIRI under its menu.
2. It should be connected with a server because processing of data will be done through a server. Your iPhone will send the voice command to the server and it will give you a response. You will need 3G or Wi-Fi connection to do this.
Hi, you need to turn on siri first or you need to enable Siri in order to use the voice application.
First of all you need to connect to internet to access Siri on your Iphone 4s.Siri is an advance feature on your phone on which you can talk or ask Siri about anything, it can do the thing you ask for it to do, for example Siri can make a phone call, can send text messages, can control music playback, it can also create and view events, its like having a personal virtual assistant on your cellphone.
You can activate Siri on your iphone 4s by enabling it then open the application and ask Siri.its kind of slow in the first time you use it because its trying to remember your voice command but as soon as you use it regularly it will be faster on responding to your questions.
