How to use ssh storage service in Windows?
Hi experts! Is it possible for me to use an ssh storage service in Windows? I am quite loss on how to use this tool. Can someone assist me on how can I download it and how does it work?
Hi Nicki,
To set up an SSH server in windows you will need the following :
1. PC with Windows OS.
3. Open port 22 on the PC
After Installing FreeSSHD program you can then use this software to connect to your PC remotely via SSH and even use it as e remote storage.
A great feature about this problem is that allows you to use the SCP copy command in order to move files in and out of the PC. You can administer different users via a GUI based interface so it will be easy to administer who will access your PC and who not.
For me is the best and easiest solution out there to make an SSH server on your Windows based PC.
Cheers,
Frazier
Notifications
