Can I install Tango App only PC? Can this set up on Mac OS? How to use this, Is it similar like What Apps? If my friend uses Tango on his smart phone with data plans, can I call in free? What is about video quality? What is a ‘Shake’ feature in Tango App? Thank You
How to use Tango App 1.6.14117 and what are features over there?
Tango is a messaging app which is an alternative to Skype and WhatsApp. You can use it to connect to friends and family, who use Tango on their smartphones, from your PC. The following Operating systems support Tango app for download on your PC: Windows XP, Vista, 7 and 8.
By using Tango, you can send free video, voice calls and receive free messages. As long as your friends and family have a data plan or uses Wi-Fi, you can call them on their mobiles for free, right from your pc.Â
You can also share updates with the use of the News Feed feature and you can also search for your friends, and for friends of your friends – the same as how this works with other social networking apps.
Using the app is very easy. All you need to do is add your mobile number and the number of the person you would like to call.
The app is very easy to use and customize. The Settings Page lets you stipulate how you would like to sort contacts, run on startup, changes skins, setup your webcam and more. Video quality is generally very good, but this can depend on your mobile device and data coverage at the time of call. Shake is a new feature of the app which allows you to meet new people just by shaking your device.
