Dana Robins
40 points
Posted on - 06/30/2013
I was having Initial version of Team Viewer in my system, which is not supporting to get connected with my client system, So I need to have Team Viewer 7 in my system, Please do let me know how to Install the same by downloading it. If there is any difference in usage procedure, Please do the needful for providing a note on how to use Team Viewer 7.
How to use Team Viewer 7
Hi Dana,
Yes, you're right, previous versions of TeamViewer may not be able to connect with newer versions.
You can download TeamViewer 7 from TeamViewer's official website. Once you have completed the download, you can begin the setup, you have the option to either install it or run it directly.
I would like to recommend watching this helpful video "Team Viewer 7 + Install, Download & Use | video tutorial by TechyV".
Hope you got the answers you were seeking. In case you need more details, please feel free to ask.
Mclean Buono
