I have just installed a total video converter on my desktop. I want to transfer my videos to more portable devices such as tablets, so I could watch the videos wherever I go. How do you convert videos using total video converter?
How to use total video converter
Hi Namat
Total video converter is very easy and simple to use.
When you launch the software, just click on Add video, and select all the videos that you need to convert.
Next step is to select the output format, select the output location (where the converted file will be saved).
And click on CONVERT
Thank you
Hello Namat,
You wanted to know how to convert videos using total video converter. Well, I will show you how. Total video converter is a powerful application that is used to convert videos into any format you want to convert your video to. Well as for your case you wanted to convert videos into tablet format. Well here are some steps as to how you can achieve that.
1. Open the video converter and click the 'new task' button and import the video you want to convert to the program so you can load several video files at time. You can preview the videos before converting.
2. Select the output formats and a pop up button will appear as “Please select the format to be converted to” window which allows you to select various output formats, here you will select “Pocket Player” and then click “apple iPad” button.
Tips: The Videos to iPad Converter allows setting different output formats according to different files.
3. Customize the output parameters such that the Video to iPad Converter allows you to customize the “Filter” and “Settings” on the left top corner. It will help you set the relative “Audio Options”and “Video Options”, “Video resize” and “Video Crop and pad”.
4.This step you will choose the output file destination below the preview monitor and setting “profile”, here you can select normal quality, high quality and lower quality.
5.click “Convert Now” to Start the Video to iPhone conversion and wait for a few minutes.
