How to use touch screen monitor
I have a touch screen monitor. But I do not know the screen how use so I want to learn about the using touch screen monitor. If anyone can do it please help me to solve this problem.
Hello just a simple information in using a touch screen monitor:
Make sure to test the touch screen just to make sure if the controls are correct. Just use your fingertip in pointing and option and control on the screen just like if your using a mouse. To make sure the unit properly just read the guidelines in detail, you can also watch some video tutorials as well.
LCD touch screen monitors has also a light pen. If you don't like to use your fingertips you can also use this pen, it can also minimize cleaning. Most of the time, fingertips become oily or dirty that may cause blur in the screen and it can require a lot of cleaning. That's it. Thank you and good luck.
