Brenda Lopez 20 points N/APosted on - 10/02/2012
Hello guys,
I just got my new mobile phone and I am not familiar with the functions and settings needed to be configured. I need your help on how to use tourist map for Nokia n8 00? How can I set up it to see the map working?
For using these map application. It is better to use video tutorial rather to use text based tutorial. I am here posting a video which will completely illustrates how can you use that application. These software are of same kind so if you have basic idea of using single app you will able to use all map applications
1....
