How to use Transmute Portable
I recently heard about this bookmark transferring software Transmute Portable.
I want to know more about this software. some one please give me some review about this software.
Hope some one will give me a reply
Users can move the bookmarks or favorites from a browser to another via the Transmute Portable particularly if users don't want to smash with the settings of your browser. Using the Transmute Portable is pretty easy. You just need to pick the source and the selected browsers and it will automatically find the location of the bookmarks. Just click the Export button.
The Transmute Portable will sustain the original form of the folders located on your browser. Transmute Portable is an effective way to import bookmarks on your browser and it is very easy to use. You don't need to install anything and it is supported with major browsers such as Firefox, IE, google chrome, Opera, Safari, Chromium, Flock, Konqueror and a lot more.
The Transmute Portable is a bookmark converter that can import and.
Export bookmarks,Or favorites from one web browser to another.
The software has made it easier to switch web browsers and still allows you access to your bookmarks, or favorites. The software is very easy to use. If you decided that you wanted to change browsers, but do not know how to export/import your bookmarks, or favorite then this software will assist you in doing so.
Once you have made your selection of the browser(s) you prefer it will instantly find your bookmarks, or favorites location for exporting. It is compatible with large number of browsers Internet Explorer, Firefox, Safari, Opera, Flock, Chrome, Chromium, and Konqueror.
This software requires no installation.
