How to use universal restore?
I want to upgrade my computer using universal restore but I don't know how. Can anyone help me on what do I have to do?
Hi!
Here's the tip i recommend you on how to use the universal store.
1. Insert the Disc of the Acronis Bootable Rescue Disc and wait for the Acronis True Image hom.
2. When the " Recovery " option appears, select it.
3. Just click the left click of the mouse on the next so that it move past on the Recovery Wizard.
4. Select the backup picture you want to recover from the list of options.
5. Select " Partitions " and select for which partitions you wish to restore.
6. Select the partion's location for where it has to be restored.
7. Choose " Active " from the "Restored Partition Type" section.
8. Press "Use Acronis Universal Restore".
9. Press "Next" and check the summary of the. If it is accurate then click " Proceed ".
I hope that it help's you regards to your problem. Have a great day!
