How to use VPN server backup ?
I would like to understand how I can store back p through VPN server as a back up tool for our system. Is there any tutorial I can access and read through to help me understand more or online guide available about VPN server backup will be highly appreciated.
Best Answer by Paul jolie
Answered By 0 points N/A #163640
You can back up your system through VPN. You need to apply either cPanel or Backup Exec for creating the backup process. For the aforementioned process, use cPanel boxes to store the indexes of your database.
If you want to use Backup Exec, then install it and use it as back up tool.
Answered By 15 points N/A #163641
Hello Denise,
You can backup through VPN server by “Backup Assist”.
The great advantage of “Backup Assist” is that, it capture ‘live snapshot’.
You can download the “Backup Assist” from here: https://www.backupassist.com/BackupAssist/download2.php
But, this is a trial version. If you want the full version, you need to buy it.
But, make sure that your VPN tunnel is established.
You can gather some information from here: http://www.internet-computer-security.com/VPN-Guide/VPN-Tutorial-Guide.html
Best of luck and have a good day.
