How to use win95 booting iso file for formatting.
Hi all experts,
I am using windows 7 on my laptop, but now I want to install/ reboot to Win95 on after creating a partition. I have win95 booting ISO file, can anyone educate or provide online tutorial for installing Windows95 via an ISO file.
Answered By 0 points N/A #157866
Burn the .iso file into a CD.
Make the CD bootable using the "Make CD bootable" option which is normally provided in most image burning soft wares.
Shutdown your computer and insert the win95 bootable CD into the CD Drive
Boot your computer paying attention to instructions on the screen. Depending on your computer, it will prompt you to press a key to boot from CD. Press the key.
During the installation process, you will be required to choose a partition for the installation or create one. Choose the one you created on create one now
The installation process will continue until it gets finished
Good luck
