How to use winamp USB control?
How to use winamp usb control? I don’t know the proper set up of winamp usb control, can you also please specify the compatibility measurements? What operating system which is compatible with winamp usb control? This is the first move to do before the installation of driver process.
Thank you.
Waiting for your support.
Answered By 0 points N/A #178840
If you want to solve your problem, buy a USB to serial adapter, or you can make it yourself. Here are the materials you need to make one:
1. 4 push-buttons
2. SERIAL connector
3. Connector Box
4. Cable
5. Soldering iron and accessories.
If you can make one successfully, your problem will solved. For more information, see this link: http://www.instructables.com/id/External-Winamp-Control/
