I am not familiar with the option of windows 7 sound management. What is the use of windows 7 sound management in the operating system? I need an expert suggestion for this question that is familiar with this option in windows. Also tell me the procedure in order to change the setting of windows 7 sound management.
How to use windows 7 sound management?
There are two different ways to edit the volume control in your system one through the system tray and the other is through the control panel.
In control panel you will see an option like 'RealTek HD audio manager' or 'RealTek Audio manager' double click on that and you will be seeing different options where you can edit those all and do the changes.
The other way to decrease and increase the volume in your system is by opening in the system tray. There you will be seeing the speaker symbol which is the option to edit the sound in the system. These are the two different ways where you can actually change the sound settings in your system.
Dear,
Using Windows 7 you can control your overall sound system in two ways. The quickest way to change the sound, click the speaker icon on the notification area of the taskbar. Then you can move the slider increase or decrease the sound. The other way to control the volume, use the Control Panel of Windows 7 operating system.
Thank you.
