Trevor Jhon
40 points
Posted on - 11/25/2012
Hello friends,
How to use a Windows Server cleaner? I just realized that I have to take good care of my computer with windows xp operating system. I need to be aware about the condition of the operating system as well as the registry, so I have to maintain it clean and away from harmful viruses. I hope you can give your best suggestion.
Thanks and Regards,
Trevor Jhon.
How to use a windows server cleaner?
Just like an ordinary windows, you can use software to clean it. Use C Cleaner to clean the system or to clean your system registry. C Cleaner is available in the internet. But if you would want that it will automatically scan the whole system just set you C Cleaner Scheduler. So as that, you don’t do it manually.
Regards!
There are lots of ways on how you can clean and take good care of your Computer especially when it comes to software.
You can use a Disk Clean up, just go to My Computer > right click on your Local Disk > select properties > then select Disk Cleanup.
You can also use Defragmentation, in properties > click tools > then click the Defragment Now button.
You can also use different software or application that cleans your PC.
And always make sure that your anti-virus is updated to prevent virus to get in your computer.
