Hi
I have word 2010 xaml convertor add-in installed.This add-in converts word documents to xaml format.I want to convert a microsoft word document into a flow document so that, i can utilize this flow document in my wpf application.Anyone, please tell me the right way to do it.
How to use word 2010 xaml add-in?
To convert your word document to WPF file
1. First save the word document as a rtf file the import it into your flow document
2. There is a software solution (WORD2XAML) that does the inter-conversion for you without altering the original formatting. The software can be downloaded from site.
3. Another conversion tool can be found at website then by following the short instructions given there.
