jen dessin
Posted on - 12/05/2012
Hi Experts,
I am using MS Office 2007 in Windows 7 OS. Please suggest me, How to use MS Word 2007 for offline files.
Whenever My connection disconnect and try to save the document.
I found following error: "There have been a network or file permission error".
Please Send me the proper solution for this issue.
Thanks!
Best,
Jen Dessin
How to use word offline file
Good Day Jen,Â
To me it seems that you are trying to save the file to a network location thus the error when you are not connected to the network. Your best bet is to save the file to your local disk instead of the network location.Â
All you need to do is: When you click save as, change the location to where you would like to save (eg. Documents or Desktop), name it and click save.Â
I hope this was a help to you.Â
There's another solution besides saving on local disk, you should try saving the file on mapped drive, to do so, do the following:
Start > Explore (on the shortcut menu) > Tools > Map Network Drive (select map drive you want to connect) > in Microsoft Word change the Save in box to the mapped drive you selected.
Hope it helps!
