How to use YouTube faster on mobile phone?
Hi guys.  I have the YouTube app installed on my iPhone but it loads so slow and buffers a lot.  Does anyone here know how to use YouTube faster on mobile?  I have the 32 GB LTE iPhone 5 that has the Apple A6 chipset, Dual-core 1.2 GHz CPU, PowerVR SGX 543MP3 (triple-core graphics) GPU and iOS 6.
Best Answer by Huffman Serafin
Answered By 0 points N/A #198534
Hi Dorethadhoward,
Using the YouTube app for mobile phone is the most suggested way to view YouTube mobile because it uses the 240p format that is very suitable for mobile phones, however, I would like to recommend to check if there is an existing option for viewing resolution and/or it uses a mobile browsing while using the application, choose the 240p format and use m.youtube.com for your convenience
Answered By 5 points N/A #198536
Use can try using Opera browser which will load faster and smoother. Or maybe  its due to slow connection or high traffic. So try using it during off peak hours, the videos will be much smoother. You can still try " Online Video Hunter ". This will help you download and convert your favorite videos & music from YouTube.
