How to view an action script in Shockwave Flash?
I need to quickly see an overall picture of the action script of a Shockwave Flash. What is the best way of doing this? Also, is it possible for each button in SWF Quicker to have different uses that are independent of each other?
Answered By 20 points N/A #105370
Hallo Kaydene Kommock,
You can view action scripts in shock wave using a third party program called Action Script Viewer, which itself is a shock wave flash decompiler program and runs on a windows 32 platform.
With Action Script Viewer, you can be able to see the action scripts in the flash movie files, and with it too, you can be able to look for any internals which are in the shock wave flash files and let you see information about frames, instance names, movie clips and so forth.
In case the shock wave files have been corrupted you can reconstruct them by exporting the shock wave flash resources and then using the JSFL command for doing the same task.
__
Regards
Mahesh Babu
