How to view in android outlook msg file? I have a business travel for next week’s activity and I need to drop all my files from my computer to my Samsung Galaxy S android mobile phone device. I cannot also bring with me my laptop so I have no choice. What is the step by step process to be followed?
Thank you.
Jessica Allen.
Hello Jessica
I found solution for your problem .You can download MSGViewer. It is written in Java and it runs on Android. It enables you to open Outlook messages without using Outlook. It is very straight forward so you will be comfortable with it.
You can download your application at this page: http://freshmeat.sourceforge.net/projects/msgviewer
I suggest you open an account in outlook.com before you travel. You can then access your outlook.com in your mobile phone or mobile gadget without even downloading a software or tool for opening outlook messages in your android gadget. Upon sign-in at outlook.com, it would automatically load your contacts and existing messages.
Then you can access all of these, including your outlook.com account via a browser in your Android gadget. Just log-in in outlook.com on your web browser and you can now access your messages.
Here's how it will look like:
Taylor
louis
Dear Jessica,
You can view your outlook msg file on your Samsung Galaxy S android mobile phone by two ways. One is creating outlook account and another is software. I think you can use any one of them. I suggest you to use MSG viewer software. This very easy methods. It’s also a free software. So download the software and enjoy.
Thanks and Regards
Louis
Hello Jessica,
There are two ways of viewing an Outlook message file into your android. You can access this either programmatically or by using a software. I think using a program is good one but it takes much time. So it will be better if you use a software.
You can use MSG viewer software. You can read or extract any MSG that is created by MS outlook. So download this from below link and extract all files into this. You can see all mail information from this.
Visit this link this link to download MSGviewer. http://www.softwaregeek.com/android-MSG-file-reader/p1.html
