How to view .djvu files-help required
I have a .djvu file which is necessary for my work. I do not know how to open this file or what to use in order to open this file. Currently I am running short of time so I need to know the answer quick. please someone help me solving this problem as quick as possible.
John Parker
Answered By 20 points N/A #116640
Hey John!
The file you are asking about is basically an advanced compression technology and high performance value. It is use to distribute the high resolution images on DVDs and on internet.
So here is the solution for you, to extract this file you must have software. Well I would recommend you Windjview 1.0.1. It is very easy and very user friendly. I am also using the same software.
You can uncompress your files with the help of thus software.
Here I also added the link to download this file:
https://www.openwith.org/file-extensions/djvu/1592.html
Hope it will help you to show your files.
Thanks
Tunacao caaron.
