Noah Jessie
90 points
Posted on - 03/21/2013
Hello Friends,
I am having 4 systems connected in Network, I am using Windows XP in all the systems and all systems are having webcam, Please advice on how to view local network computer webcam, Is there any software for accessing Network Webcams. Please guide me,
Thanks & Regards,
Noah Jessie
How to view local network computer webcam
You can try Camcloud. It supports video surveillance and video streaming integrated with a private cloud infrastructure. You don't need to purchase proprietary hardware, you can use any AXIS IP camera. And you don't need to install any software since the entire motion detection functions will be viewed from your browser. So practically, you don't need to setup or configure anything. Visit their official website for pricing and how to get it. The link is provided below:
https://www.camcloud.com/
Another one is the Netcam Watcher Professional. This is a Digital Video Recorder (DVR) type that works with IP cameras. You can get it from the link below:
http://www.netcam-watcher.com/index.php
