How to vpn capture cisco
How to capture Cisco VPN AnyConnect client logs. I want to use Ipsec client VPN capture Cisco. Please suggest the real facts about that. I appreciate all solutions.
To capture Cisco VPN Any Connect Client logos, you have to follow some steps.
Hi Effielclyde,
I have searched the Google for this answer and I think it was very much effective for you.
1. Choose Start — Run
2. Type in eventvwr.msc/s
3. Expand the "Applications and Services Logs"
4. Right-Click the Cisco AnyConnect VPN Client log and select Save Log File As Any Connect.evt
You may also join the discussion on this forum for more information.
