Hello friends,
How was galaxy tab working with excel? My galaxy tab was just reformatted because of those malicious ware viruses that attack the operating system and for this time I want to be more careful to avoid some problem again. I just want to know if galaxy tab is compatible of handling excel data and application?
Thanks and Regards,
Amanda Mitchel
Galaxy tab is supported documents types like word, excel, power point and pdf. So galaxy tab is compatible of handling excel data and other application. Working excel on the tab is a not hard and input data is very simple but you have to be aware that more complex formulas that were added in excel some may not work. Â To avoid virus in you Galaxy tab you have to be careful in downloading you have to download software which is protected with license. Hope it will help and give you additional information.
